Creating XML Input Data Source
The XML connector allows the retrieval and processing of XML files, either from a disk, a Text, or from a defined URL.
1. In the New Data Source page, select Input > Xml in the Connector drop-down list.
2. Select the XML file source:
· File
You can either:
¨ Upload a data source snapshot by clicking Upload File
then
Browse
to browse to the file source.
After selecting the file, it is displayed with the timestamp of the snapshot.
To change the data source,
click
then
Browse
to browse to a new version
of the file.
¨ Link to a data source file by clicking Link to File
and
entering a XML File Path.
Ensure that in a cluster, you need to use a a shared path, or put it on every node and use a path that resolves on every node. You can update its contents whenever you want.
· Text
Then enter the text block to be parsed.
· Web URL
The dialog changes to allow specification of the following:
Property |
Description |
Path |
The absolute path including the http where the Xml file is located. |
Proxy Server URI |
The HTTP Proxy setting that will allow the XML connector to reach the endpoint |
Headers |
· Headers are separated by a comma · Each Header is entered as Name = Value, where Name and Value can be enclosed in double quotes to allow inclusion of any character except for double quotes · Name and Value can also be left unquoted, in which case they may not include comma or equals characters |
Content Encoding |
Select the Content Encoding with the HTTP Header: None, GZip, Deflate, or GZip and Deflate |
User Id |
The user Id that will be used to connect to the XML service. |
Password |
The password to connect to the XML service. Check the Show Characters box to display the entered characters. |
Http Method |
Select the HTTP Method to map any of the following operations to HTTP requests
· GET – retrieve information · POST – create or update an entity · PUT – replace an existing entity · DELETE – remove a request |
Timeout |
The length of time to wait for the server response (10 to 300). Default is 10. |
Request Body |
The Request Body for HTTP POST. |
Content Type |
The required Content Type. Default is application/x-www-form-urlencoded |
3. Enter the Record XPath (e.g., //myroot/items/item).
4. Select either the period (.) or comma (,) as the Decimal Separator.
5. Click
to the fetch the schema based on the connection
details. Consequently, the list of columns with the data type found
from inspecting the first ‘n’ rows of the input data source is populated
and the Save button is enabled.
6. You can also opt to load or save a copy of the column definition.
7. You can opt to click
. A
new column entry displays. Enter or select the following properties:
Property |
Description |
Name |
The column name of the source schema. |
XPath |
The XPath of the source schema. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message should be processed. |
To delete a column,
check its
or
all the column entries, check the topmost
, then click
8. Click
The new data source is added in the Data Sources list.
