Create Profile and Revolve
Geometry > Body > Create > Extrude/Revolve > Profile
This tool allows to define a polygon and revolve about an axis. It will create a solid body with hex and wedge elements. Polygon can be defined by picking either nodes or vertices. The points to define polygon should be selected in sequence. The spider wedge elements along the axis of revolution can be avoided by checking the option All hex. Polygon and mesh definition can be exported as template and imported back.
