Identify Bodies To Hex Mesh
This tool identifies the hex meshable bodies based on body types. Users can specify the type of hex mesh bodies for identification.
Body Types
- Axis symmetric
Partial or 360 degrees revolved axis-symmetric and cyclic symmetry bodies are identified using this option.
- Screw
Screws and bolts with slotted head/ threads are identified using this option.
- Pipe
Pipes, tubes and wires that have solid/ hollow cross section are identified using this option.
- 2.5D
Bodies that have a smooth top and bottom faces that are separated by end faces are classified as 2.5D.
- Sweep
Bodies that are swept from one end to the other with varying cross section along thickness are identified as Swept bodies.
- Extrude in one direction
This option is used to identify bodies with all the components extruded along the same direction.
- Extrude in multiple directions
This option is used to identify bodies with the components extruded in multiple directions with steps and bends.
Input
Output
