Create Hex Between Faces
Mesh > 3D Mesh > Hex > Between Faces
This tool is used to generate a Hex mesh body between two sets of input quad faces. Select faces on both sides and specify the mesh size. It will create a Hex mesh body with matching mesh between the selected faces.
Input
Output
