setUserDefinedSettings
Overview
This utility is used to set the user defined settings for the current session/script/project.
simlab.setUserDefinedSettings(UserDefinedSettingsFile(*.ini))
Use Case
Some automation projects do need the customized settings to enable/disable some features specific to the project.
Sample
simlab.setUserDefinedSettings("D:/MySimLabSettings.ini")
Note: For the settings that require restart of SimLab, set the
environment variable "SL_USER_DEFINED_SYSTEM_SETTING_FILE" to the user defined
settings file instead of this script utility.
