getVertexPositionFromVertexID
Overview
This utility is used to get XYZ coordinate of vertex using its ID.
Center = simlab.getVertexPositionFromVertexID("ModelName",VertexId)
User Case
  • To create Orphan Node by getting the XYZ of vertex
  • To calculate the distance between two vertex in scripting
Utility Input/output
