getNodePositionFromNodeID
Overview
This utility is used to get XYZ coordinate of a node using its ID.
Center = simlab.getNodePositionFromNodeID("ModelName",NodeId);
User Case
  • To calculate distance between two nodes in script
Utility Input/output
