Body Force
This option is used to define Body force for the simulation.
- Constant Body Force
For constant Body force, the vector and magnitude must be specified. By default, the magnitude is 9.81 m/s2. It can be specified in the desired direction using a vector.
- Variable Body Force
The user must define a time vs acceleration table.
