Training
What are the various architectures available in PhysicsAI?
PhysicsAI has three proprietary architectures:
  • The Graph Context Neural Simulator (GCNS) is based on graph neural networks. The GCNS method was the only method available in SimLab version 2025.1 and in earlier versions. The GCNS method performs well on most applications.
  • The Transformer Neural Simulator (TNS) is based on the transformer architecture and is available in SimLab version 2025.1 and beyond. The TNS method is mesh invariant and is best for predictions on CAD models.
  • The Shape Encoding Regressor (SER) is based on shape encoders and available in SimLab version 2025.1 and beyond. The SER method capability is restricted to quick KPI predictions (no field results).
A comparison of the three architectures can be found in Table 1.
In Table 1, the symbols have the following meaning:
  • ✓: the architecture has the capacity.
  • + and -: indicate relative performance on the given criteria.
Table 1. Architecture Comparison
Table 1.
GCNS TNS SER
Contour Output ✓ ✓
KPI or Curve Output ✓ ✓ ✓
Mesh Input ✓ ✓ ✓
CAD Input ✓ ✓
Custom Inputs ✓ ✓
Contour Smoothness ✓ NA
Training Time - +
Training Stability - +
GPU Memory + - NA
Do I need to include simulation entities like thickness, materials, loads, boundary conditions, and so on in my PhysicsAI training?
Not necessarily. These entities only need to be included if they vary between training samples. For example, if thicknesses are constant across all elements in all meshes, then there will be no benefit to including them in training. The same is true for other entities; only data with variation is important. However, if thickness, or other entities, vary from one training sample to another, then it is necessary that you include them in PhysicsAI training to obtain quality predictions.
What entities are natively supported?
The following entities are automatically parsed by PhysicsAI in HyperMesh (Not in SimLab)
Table 2.
Version Solvers Entities
2025
OptiStruct
Radioss
LS-DYNA
Nastran
Abaqus
ANSYS
Thickness
Material ID
Restriction: The thickness entity works with thickness assigned to properties and properties indirectly assigned to elements. Thickness or properties assigned directly to elements is not supported.
Can PhysicsAI handle training files with missing results on some parts?
Yes, in PhysicsAI 2025.0 or later, parts without any results are automatically detected. Using the label IDs, these parts are excluded during training as well as prediction.
Can PhysicsAI handle element erosion?
Yes, eroded nodes (nodes with no element connections) are ignored.
Do all the meshes in the training data need to be aligned? Does PhysicsAI have any utilities for this?
PhysicsAI is sensitive to location and orientation of training data. In PhysicsAI 2025.0, meshes can be translated using the center of gravity to the origin of the reference coordinate system using the Mesh Alignment Feature. For details, see Train Models.
When should I use transfer learning?
Repurpose a PhysicsAI Model
Adapt a generic model for a new class of designs.
Update an Existing PhysicsAI Model
Use the old model and new data to create an improved model.
