Predict Results
Use the predict tool to generate a model prediction.
Verify, a PhysicsAI model has been set to Active in the Model Browser. An active model will be used in the prediction.
  1. Drag-and-drop an FE model file into the new database window.
  2. In the Load File dialog, define the options for the model and click OK.
    Note:
    To maintain performance, the license for PhysicsAI is drawn when a model is loaded as active. To release the license, the model should be released.
  3. In the Import Options dialog, click Import.
    The model opens in the modeling window.
    Note:
    If the model was trained on specific components, import the full assembly, isolate the trained components, select them, and then run Predict. Only the selected components will be evaluated.
  4. From the PhysicsAI ribbon, select the Predict tool.
    Tip:
    Information panel: The panel shows the active model and the unit system. The unit system is taken from the current display units; change it if needed. If the database is opened with units disabled and a raw solver deck is used, you can accept and proceed.
    Displayed Unit System
    The prediction result will be loaded into the same database.
