Computing and Resources
Is a GPU required?
A CPU can be used to train a model, but it will be slower than a GPU.
What GPUs are supported?
This requires a NVIDIA GPU that has a compute capability > 6.0. See the NVIDIA website for more information on the compute capability of specific hardware.
How do I enable NVIDIA GPUs for PhysicsAI training?
- Verify the GPU is supported.
- Launch and use SimLab.
Supported GPUs will be automatically used.
What effect does GPU and dataset size have on training times?
The quality of computing resources will affect training time. Better hardware can improve run times, but improvements from CPU to GPU can be substantial. Regardless, training time is linearly proportional to dataset size. See the table below for a representative example:
| Hardware | 10 Result Files | 50 Result Files | 100 Result Files |
| Laptop CPU | 44 m | 3 h 35 m | 7 h 54 m |
| HPC CPU | 34 m | 2 h 46 m | 5 h 10 m |
| GPU | 3 m | 16 m | 33 m |
Can I train on an HPC?
Yes, more information is available here.
