Shell
Remove material and create thin walls to generate a shelled part.
On the Geometry ribbon, select the
Shell tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the
currently displayed tool. - Click and hold the currently displayed tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select
- Select one or more faces to remove.
In the microdialog, enter the desired thickness for the new shell.
Note: Click the Reverse Direction
icon to reverse the direction of the
shell. -
Click Apply
on the guide bar or microdialog to generate the shelled part.
Create or Assign Variables to Parametrize a Model
Create or assign variables to parametrize a model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools and contexts.
