Extract
Extract selected geometry features and transfer them to a new part.
On the Geometry ribbon, select the
Extract tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the
currently displayed tool. - Click and hold the currently displayed tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select
Select a sketch, face, edge, or point.
Note: Your first selection sets the selection filter. For example, if you select an edge, then your remaining selections must be edges.
- Select additional features to extract, based on your first selection.
Optional: Click the
icon in the microdialog to break the reference
between the original part and the extracted part.
Note: If you wish to restore the reference, you must click the
icon before clicking
Apply. -
Click Apply
on the guide bar or microdialog to extract the selected features and create a
new part.
Tip:
- Entities selected from the same original part will become a single new part, even if they are not contiguous.
- Entities selected from different original parts will become separate new parts, even if the original entities were in contact with each other.
