Fillets
Create fillets or chamfers along an edge.
Fillet Edges
Round edges to create fillets with a constant or variable radius.
  1. On the Geometry ribbon, select the Fillet Edges tool.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
    The guide panel appears.
  2. Choose a Radius Type:
    • Constant: Create fillets with the same radius for every edge.
    • Variable: Create fillets with a variable radius at selected points along the edges.
  3. Choose a Continuity type:
    • Tangent: Force tangent (G1) continuity along the edge.
    • Curvature: Force curvature (G2) continuity along the edge.
  4. Create and modify edge sets:
    To Do this
    Add an edge set
    1. Click the + button and select the edges.
      Tip: In the microdialog, select Tangent Propagation so that clicking an edge will also select all of its tangent edges.
      To select all of the boundary edges of a face, click the face.
    2. You can adjust the Radius for each edge set.
    All edge sets will be part of one fillet construction feature.
    Delete the current edge set Under Edge Sets, click .
  5. Create a modify points (Variable radius only):
    To Do this
    Add a point where the radius varies Click along the edge.
    Delete selected points
    • Under Points, click .
    • Alternatively, in the modeling window, select a radius handle and press Delete.
    Modify the point’s position along the edge Enter a value from 0 to 1, where 0 and 1 correspond to the edge’s endpoints and 0.5 corresponds to the mid of the chain. You can also select the radius handle and drag it along the edge.
  6. Click Apply.
    Features are automatically retained and notches are preserved on sheets.
  7. Right-click and mouse through the check mark to exit, or double-right-click.
Tip:
  • By default, clicking an edge will also select all of its tangent edges. Deselect Tangent Propagation in the microdialog to disable this behavior.
  • If the fillet radius text box is highlighted red due to an invalid edge selection, press Ctrl+Z to undo or press Ctrl while clicking to deselect the edge. The previously valid selection will reappear.
  • Change the default fillet radius in the Preferences.
Chamfer Edges
Create beveled edges.
  1. On the Geometry ribbon, select the Chamfer Edges tool.
  2. Select edges to chamfer.
    • To select an edge, click the edge.
    • To select multiple edges, use box selection or press Ctrl while clicking the edges.
    • To select all of the boundary edges of a face, click the face.
  3. Choose from the following options:
    • Distance, Angle: Enter a horizontal distance and an angle.
    • Distance, Distance: Enter a horizontal distance and a vertical distance.
    If you entered an invalid value, the text box is highlighted in red.
    Note: The values you enter will be automatically applied to all selected features.
  4. Select Apply on the microdialog.
Tip:
  • Reverse the side the distance and angle are measured from by clicking in the microdialog.
  • If a distance/angle text box is highlighted red due to an invalid edge selection, press Ctrl+Z to undo or press Ctrl while clicking to deselect the edge. The previously valid selection will reappear.
  • Change the default chamfer distance and angle in the Preferences.
Create or Assign Variables to Parametrize a Model
Create or assign variables to parametrize a model. Variables can be created from a tool or the tool’s microdialog where f(x) is present.
You can create or assign existing variables via the microdialog or in various tools and contexts.
Keyboard Shortcuts & Mouse Controls
To Do this
Select features Click
Append/remove feature selection Ctrl+click
Delete selected feature Delete+click
Delete selected filleted/chamfered face Delete
Exit tool Right-click and mouse through the check mark to exit, or double-right-click.
