Delete Faces
Delete faces from solid or sheet parts.
                On the Geometry ribbon, select the Delete
                        Faces tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
 at the lower right corner of the
                                currently displayed tool. - Click and hold the currently displayed tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select
                Select one or more faces.
                Note: To deselect, hold down Ctrl while clicking.Selected faces are shown in red.
                Select a red face to delete it, or click Apply
                    on the guide bar to remove all red faces.
