Patch
Fill in a missing surface.
On the Geometry ribbon, select the Patch tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the currently displayed tool.
- Click and hold the currently displayed tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The guide panel appears. - Select
Next to Edges, the Select button is active. Select one
or more edges. An edge can be a sketch or curve.
Note: To select all connected edges, turn on
Select Connected Edges. When you select one edge, the entire chain of edges is selected.
To deselect, hold down Ctrl while clicking.
- To group the selected edges into a single edge set, turn on Group Edges. Turn off this option to define the continuity for each edge.
Define the Continuity for the Edge Sets:
- Position (G0): No constraints are set; the patch surface is connected to the surface edge, but not tangent to it.
- Tangent (G1): The patch surface is made tangent to the surface edge but does not follow the curvature of the adjacent surface.
- Curvature (G2): The patch surface is made tangent to the surface edge and follows the curvature of the adjacent surface.
- Next to Internal Curves, the Select button is active. Select internal curves. An internal curve can be a sketch or curve. To deselect, hold down Ctrl while clicking. To also select all the tangent edges when clicking an edge, turn on Tangent Propagation.
- To merge target and patch surfaces, turn on Merge Result. Turn off this option to make the patch a new part.
- To show all open loops, which could be patched, in the model, turn on Show Open Loops. Otherwise, turn off this option.
- Click Apply.
