Vendor Registration
Register the vendor manually for the air-gapped environment system.
In the case of air-gapped environment system:
  • Vendor do not send any data to the server automatically, the vendor registration must be done manually
  • The data is archived once a day on the air-gapped agent machine
  • The data is transferred from the air-gapped system to the server manually
  • Provides an easy way for the administrators to ingest the data received from the air-gapped environment to the server
  • The server provides an easy way for the administrators to upload data from air-gapped vendors using portal GUI
