What's New
New features available in InsightPro for License Analytics.
Organizational Hierarchy
- The Sync Servers option in the Organization Hierarchy tool performs data synchronization from each defined Active Directory (AD) server and updates the created hierarchies with the latest information.
- Configurable parameter to filter the parameter for active users in AD (For example, userAccountControl).
Reporting
Enhanced Usage Efficiency and Reservation Efficiency binning to support token-based licensing systems.
Smart Agent
- Smart Agents can now be installed in a user-specified location and run under a non-root or system user account.
- Upon startup, Smart Agent now schedules monitored vendors in sequential order to better distribute machine resource usage.
- The Smart Agent auto-discovery script is now written in native Golang, replacing the previous PowerShell (Windows) and Bash (Linux) implementations.
- Timeouts are better now specially to work smoothly when agent is working against slow machines/network.
- When monitored vendors take longer to respond than the polling cycle, then the next cycle is canceled and not queued.
Project Assignment
Introduced LM_PROJECT assignment to users to support Altair Monitor use cases via command-line and GUI based interfaces. License Server Statistics project attribute is parsed for license vendors who support this.
Improved Logging
- Logging is improved across the product based on recent customer interactions and field feedback to facilitate debugging across the product.
- Clickhouse system logs retention policy is fixed now to avoid indefinite retention.
License Parsers
- Bug fixes in FlexLM, Kuli, and LMX vendor handling.
- An example of License Server Parser Plugin based on CSV data format is packaged in the product. This is extremely helpful in cases where a particular license vendor is not supported by OTB list and field team / customer wants to add this support using our extension mechanism.
Other Enhancements
- NavOps and InsightPro for License Analytics can co-exist on same machine provided if they have enough hardware resources.
- Various functional and performance bug fixes.
