Organization Hierarchy
Organization Hierarchy provides an easy way to import the data from the Active Directory (AD) after performing validations and cleaning up the data.
Software costs represent a significant expense in any organization. Software tends to be very expensive. Corporations establish budgets for different departments, regional locations, or even budgets for managers. All expenses are budgeted for. These can include personnel costs, equipment costs, software costs, administrative costs etc.
If a corporation needs to determine budgets for software expenditures based on historical usage, it is necessary to have information about software expenses for departments or regional offices or managers.
It is possible to define these hierarchies using data available in LDAP or Active Directories, where every user’s record has information about their department, location and reporting manager.
InsightPro for License Analytics includes a graphical module which enables connecting to an LDAP system to import data for all users and then define such structures based on appropriate and available attributes.
After such hierarchical structures are defined, these are available to all Insight Pro modules such as HPC Analytics & Reporting, Software License Analytics and Desktop Software Usage Analytics. These structures enable companies to obtain breakdown and rollup by each defined hierarchy. These structures also enable companies to calculate charge-backs to various departments or regions or Managers based on various usage metrics.
- an easy way to clean up the AD data before importing the user records
- allows the administrators to edit the hierarchy
- the modified hierarchy data are reflected immediately
- ability to define multiple levels of hierarchy
- allows how users are assigned to a certain node based on:
- resources in a HPC cluster
- software licenses from company managed license servers
- launch an application
- set multiple levels based on certain attributes of a user:
- region → country → city
- country → department
- set the levels and their relationship by providing the name to each of the level
- faster way to recreate the hierarchies without reparsing
- write hooks to intercept every record from the AD to perform custom filtering
- provides administrator's an easy access to performs tasks, access information, and troubleshoot issues
