Release Notes
Resolved Issues
Here is the list of issues that have been fixed:
- MON-1264: Added a duplicate entry check to InsightPro set config --register-url command to verify if a URL is already registered.
- MON-1466: Improve InsightPro for License Analytics installation script to check for the disk space before upgrade, so that the upgrade won’t fail in the middle due to insufficient resources.
- MON-1592: High memory usage by the LM Agent when the vendor query is consistently slow.
- MON-1647: DSLS Denials are not parsed by the LM Agent.
- MON-1653: Ability to run InsightPro for License Analytics Agent for Linux as a Non-root user with a different service account.
- MON-1659: The Notification Setting panel does not allow characters like - and _ to be entered in the email input box.
- MON-1666: Vendor picklist gets stuck if a previously selected vendor is deleted
- MON-1671: Usage efficiency report is not reporting the correct values.
- MON-1676: Vendor Registration tool is not reflecting whether the vendor is remote or not.
- MON-1714: InsightPro for License Analytics cannot checkout a license again without having to restart the server.
- MON-1717: Run InsightPro for License Analytics Agent for Windows as a Non-root user with a different service account.
- MON-1784: Installing InsightPro for License Analytics agent in a non-default location.
- MON-1787: Remove unused variables from the SAO legacy migration tool that have a path to avoid unnecessary issues.
- MON-1788: Denials check-in time is not set correctly, as a result the server discarded all the denials.
- MON-1794: Installation script is not checking the correct disk space for installation.
- MON-1800: Export historical records are not working as feature filter is not applied correctly.
- MON-1813: Make the Active Users filter during Data Import configurable.
- MON-1814: LMX license file is not parsed properly.
- MON-1815: Vendor schedules are overlapped when the querying takes time.
- MON-1825: Metadata for a vendor does not load when the query time takes more than 50 seconds.
- MON-1832: License Server Control dialog box for license file upload only allows .txt extensions.
- MON-1845: FlexLM parser is returning a “no feature found“ error, despite the presence of features in the query tool and expiration tool outputs.
- MON-1846: System tables in ClickHouse database is taking a lot of disk space.
- MON-1853: Improvements in .
Known Issues
Here is the list of known issues:
        - MON-1455: Installing InsightPro for License Analytics on a system with existing NavOps installation breaks NavOps.
- MON-1672: Reservation Efficiency report shows "waiting for input" message when you do not select any filter options.
- MON-1685: DryRun timing out if response time is longer than expected.
- MON-1786: Denial Report slows down when there are millions of denials.
