Create Hierarchies
Create hierarchy after importing the AD data.
The process that is followed to create new hierarchy are:
- Select AD data source - select the AD server to fetch the source data.
- Define Hierarchy - define the hierarchy as required.
- Review Hierarchy - review the hierarchy and confirm the changes.
Click Hierarchies tab in the Organization Hierarchy
dashboard.
Figure 1. Hierarchy
The list of Hierarchies added is displayed. -
Click Create New Hierarchy.
The list of AD data that is imported is displayed.
Figure 2. List of AD Data Source
Select the AD data source from the list and click
Proceed.
Figure 3. Selected AD Data Source
Define Hierarchy screen will be displayed with the Selected Attributes.Figure 4. Define Hierarchy
Drag-and-drop the attributes from the Available
Attributes to Organization Hierarchy
column.
Figure 5. Drag-and-Drop Hierarchy
Review the Organization Hierarchy that is selected.
Figure 6. Organization Hierarchy
Note: Click
to remove the empty boxes and
to add the boxes. -
Click Review Hierarchy.
The Organization Hierarchy selected is displayed.
Figure 7. Review Hierarchy
Click
to expand the attributes of the hierarchy.
Figure 8. Expand Organization Hierarchy
Note: Click Back to make any changes to the hierarchy list. -
Click Save Changes and Finish after reviewing the
Hierarchies.
The hierarchy will be added to the list.
Figure 9. Hierarchy List
Note: Refreshing the reporting portal will make new hierarchies available for reporting.The hierarchy created will be displayed in:- SLUAS Module - Select Historical tab. Select
Usage by Hierarchy Report. The new
hierarchy will be listed in the drop-down menu of
Hierarchy.
Figure 10. Hierarchy in SLUAS Module
Hierarchy.
