Create Soft Limits
View and update the soft limits by selecting vendor, feature, and active directory hierarchy.
Click Soft Limits from the left pane.
Figure 1. Soft Limits
Select the Vendor/Vendor Pool from the drop-down
menu.
Figure 2. Select Vendor or Vendor Pool
Select the Feature from the drop-down menu.
Figure 3. Select Feature
Select Hierarchy from the drop-down menu.
Figure 4. Select Hierarchy
Click
to edit the soft limit.
Figure 5. Edit Soft Limit
You can set the Soft Limits at the Country Level, Branch Level or for the Project Level.Manage Soft Limits window is displayed to set or update the Soft Limits.Figure 6. Manage Soft Limits
Click
to select the date for Start
Date and End Date.
Figure 7. Set Date from Calendar
Enter the value for Soft Limit.
Figure 8. Add Soft Limit
Click Add Soft Limit.
Figure 9. Updated Soft Limit
Note: You can edit (
) or delete (
) the soft limit entry.
