Delete a Set
- From the Create tools, select .
From the Set panel, select a set/group.
Tip: Multiple sets can be selected to be deleted.
Delete the set(s) using one of the following methods.
- Click Delete (located at the bottom of the panel).
- Press the Delete key on the keyboard.
The selected set is removed from the list.
