Sets can be edited by selecting a set in the Results Browser then
changing the attributes in the Entity Editor.
Standard
ID
The ID of the set.
Restriction: This field is not
editable.
Visibility
Activate/deactivate the check box to turn the display of the set on/off in
the modeling window.
Label
Click in the field to change the label of the set.
Entity IDs
Lists the number of entities in the active set. Click in the field to
activate the input collector, which allows you to select/change the entity
type of a set. You can also hold down Shift and left
click the collector to display the Extended Entity Selection dialog.
Display
Color
Select/change the color of the feature lines of the entities in a set using
the color box and palette.
ID Visibility
Display the IDs of entities in a set/group.
Draw Style
Select the drawing style for the active set using the input collector.
shaded (for Component sets only)
wire (for Component or Element sets
only)
point (for Node sets only)
sphere (for Node sets only)
Draw Size
Change the thickness of the wire and the size of the
point/sphere drawing for the active set.
