Access the Context Menu
  1. From the Create tools, select Create > Sets.
  2. From the Set panel, right-click anywhere within the Sets list.
    The context menu is displayed.
  3. Click on one of the available options.
    OptionsActions
    Delete Deletes the selected set(s) from the list.
    Rename Displays the Rename dialog, which allows you to rename the selected set.
    Show Displays the selected set(s) in the modeling window and activates the corresponding check box(s).
    Hide Hides the selected set(s) in the modeling window and deactivates the corresponding check box(s).
