Delete Cached Results
HyperView will hold
the cached data until it is deleted.
Note: Cached results are automatically deleted
whenever the active subcase is changed or a currently active derived subcase is
modified, a new session is started, or a model is deleted.
Delete the internal cache of the active contour result using one of the
following methods.
- From the Contour panel panel, click Delete cache.
- Right-click on the browser data item and select Delete from the context menu.
- To delete all of cached results simultaneously, right-click on the Cached results folder in the browser and select Delete from the context menu.
