Create Cached Results
Create an internal cache of the active contour result using one of the
following methods.
- From the Contour panel panel, click Cache.
- Right-click in empty space in the Results Browser and select .
Note: Whenever a result is cached, it is computed for each frame the first time
a frame is loaded, thereby making the time taken for the first time load
greater. The times for all subsequent loads will be significantly
reduced.
