FBD Import/Export
Once you have defined FBD sections in HyperView, you can invoke the Export dialog (shown below), where you can select which sections are to be exported.
From the Aerospace menu, select
.The export formats supported are:
- XML
- CSV
Once the section file has been created, it can be shared and re-used on models having the same topology or it can be modified to change the original section definition.
The Import option works accordingly supporting the same input file
definition (.csv, .xml).
