2026
The Aerospace menu provides you with access to various aerospace tools.
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
This tool allows you to have the same system defined in both HyperView and HyperMesh.
The NVH utilities are now available only via the HyperMesh NVH menu bar.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing the multicore profile for post processing results from certain solvers and crash use cases.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
