Sync Between HyperView and HyperMesh
This tool allows you to have the same system defined in both HyperView and HyperMesh.
From the menu bar, click .
Use cases for HyperView:
- You have a session with a model in HyperMesh and the same model with results in one or more HyperView windows.
- Create one or more coordinate systems in HyperView.
- Open the tool in HyperView and select the system(s) you want to create in HyperMesh.
Note: Rectangular and cylindrical systems are currently supported, however Spherical
systems are not.
