Update Link Geometries
The default option is set to Auto Calculate, this option
considers the parameters specified in the track properties section. In case of different
track link geometry, the User Input option allows modify the
dimension of the track link.
The contact points define how many points will represent that track link. The
maximum points allowed in the model is five. The X and Z coordinate of the contact points
must be referenced by the track pin center (red coordinate system). The Xcg and Zcg are the
longitudinal and vertical referential distances of link CG location from pin center. The
figure below illustrates the track links with 2, 3, 4, and 5 points.
The figure below shows an example of a CAD track link using 2 contact points and the equivalent
parameters in the Update Link Geometry dialog.
Note: The coordinate system X and Z (0,0) located in the track
pin center, shown in the picture above, indicates the contact points must be referred to
the track pin center in the Update Link Geometry dialog. This information should not be
misunderstood with the track link center location specified in the CAD file as indicated
in Create Tracks.
