Additional Information
Road Graphic Log File
The Road Tools write a log file named Road_graphic.log to the directory containing the input road file. The log file contains information about the input road file, the output driver path file or road graphics files, and any errors encountered while processing the input road file. If you process more than one road file in the same directory, the log file contains information for last file processed.
