Motorcycle - Trailing Arm - Twin Shock As the name suggests, it refers to two shock absorbers at the rear end of a motorcycle. This arrangement allows for a higher spring deflection, as the spring pick-up at the bottom is closer to the wheel center. Figure 1.
