Jounce and Rebound Systems
Jounce and Rebound bumpers restrict the upward and downward movement of suspension components.
Jounce Bumpers
The jounce bumper restricts the upward movement or compression of suspension components and is used to stiffen the suspension gradually as it approaches the end of the jounce travel and prevent metal-to-metal contact that could lead to ride harshness and suspension damage or failure. Also called as “bump stop”, the jounce bumper absorbs impact and dampens noise, vibration and harshness during shock impacts caused by heavy loads, potholes or objects in the road.
There following variant is supported in the library.
- Front/rear internal jounce bumpers
Rebound Bumpers
Rebound is the downward movement or extension of suspension components.
- Front/rear internal rebound bumpers
