Add Queries to a Simulation
You can define queries with a unique Start Time, End Time, and Interval Time similar to those in EDEM Analyst.
Select the Simulator Queries checkbox.
The Setup Simulator Queries dialog box is displayed.
In the Setup Simulator Queries dialog box, define the
queries.
After you have defined the queries, start the simulation.
The
csv
files will be copied to the folder which contains the.dem
file associated with the simulation.
