Set Simulator Parameters
You can set simulation parameters such as the Time Step, simulation time, grid options, and Simulator Engine for the CPU mode, along with the GPU parameters.
Evaluate if all the parameters within the simulation are necessary to achieve the desired outcome. You can add additional parameters such as geometry dynamics and contact models to the computational overhead, especially complex models such as Hertz Mindlin with Bonding.
