Export Results Data
You can export csv files from your simulation during run time. This allows you to generate results from your simulation without the need to save Time Step data out, therefore, reducing the data storage requirements for the simulation.
Set up a query that includes the attribute you wish to export, Start and End
time of export, and the frequency of the export.
A separate
csv
file is created per query and you can also write queries at different Start and End points with different frequencies. -
Select the Simulator Queries checkbox.
Stopping and restarting a simulation which has the Simulator Queries checkbox selected will affect the results. Attributes which are relative to the whole simulation, such as average, are calculated during the run period. Therefore, stopping and starting the simulation will generate two or more values for average.
This approach supersedes the Output Results option currently in the Simulator. If you have run a simulation and restart, the data will be overwritten or appended to the end of the file. The point at which the simulation is restarted/started is indicated by the repeating of the header in the exported
csv
file. - Add Selection and Bins to the Analyst for use with data export.
