The EEPA model includes an Estimated Parameters section to help understand the
behavior of the bulk material being defined.
Based on the model parameters inputted and the particle properties a Bond Number is
calculated. The Bond Number (B
o) positively correlates with the cohesiveness
of the material interaction, where:
The cohesiveness is stated alongside the Bond Number
value.
The Bond Number (Capece, 2015)
is derived from the ratio of the cohesive forces, Fcohesion to the weight
of the particles, Wg:
The cohesive force is defined
as:
Where γ is the mean normal overlap, r is the
mean particle radius, Δ is the surface energy and fo is the constant pull-off
force. The Bond Number will be calculated live as model parameters are
populated:
In addition to the Bond Number, critical Time
Step information is displayed in the Estimated Properties, where:
- Current Interaction Timestep
Shows the maximum
allowable Time Step for the current interaction parameters.
- Recommended Simulation Timestep
Shows the maximum
allowable Time Step for all interactions. This is found by finding the
smallest Current Critical Time step for each of the
interactions.
- Critical Timestep Interaction
States which
interaction has the smallest Time Step, and is therefore the critical
interaction.
Tip: Use the Minimum Critical Time Step in
the Solver when running the simulation.
Each interaction’s Time
Step is found using the following equation (O'Sullivan,
2004):
Where Δt is the Time Step, m is the mean
particle mass and k2 is the unloading/reloading stiffness.
k2 is defined as:
