Replace Geometry Sections
You can replace Geometry sections with new imported Geometry objects or the standard EDEM objects. These replaced objects will retain the factory, kinematic, and transform settings.
- Select the object that you want to replace.
- Right-click and select Replace Geometry.
- Select Box, Cylinder, Polygon, or CAD Geometry.
Define the object based on the option that you have selected.
Note: Geometry sections can only be replaced at Time Step 0.
