Group Geometries
You can use Geometry groups to organize Geometry sections in the Creator and Analyst trees.
To group Geometries:
  1. Right-click Geometry and then select Add Geometry Group to add a group.
    Optionally, select multiple Geometry sections and then right-click Add to new Geometry Group.
    A new group is created along with the Geometry sections.
  2. Right-click the context menu to move Geometry sections between groups or to Geometry groups.
  3. Right-click Remove from Geometry Group to remove a Geometry from a Geometry group or press Ctrl + Shift + x.
    Note:
    • Deleting a group containing Geometry sections will provide an option to delete Geometry sections in the group or only the group item.
    • If you add/import a new Geometry while a Geometry section within a group is selected, the new Geometry will be added to this group, or, otherwise to the top-level Geometry sections Group.
    • If you copy a Geometry, the copy is created at the same level in the Geometry tree hierarchy.
