Topology
Dialog Box
This is used to create a wire body from the selected FEM edges. If "Equivalence nodes" toggle is ON, then it will share wire body nodes with the selected edges. Otherwise wire body nodes will get separate from the selected edge nodes.
Note: "Equivalence nodes" toggle is supported only if the selected edges belong to
shell body.
