Identify by Size
Dialog Box
- Show
This option identifies the bodies for the given input.
- Delete
This option identifies the bodies that falls in the given category and deletes them.
Example 1 (Thickness = OFF)
Bodies identified within the given box size:
Smaller than:
Bigger than:
Example 2 (Thickness = ON)
Thin bodies identified for the given thickness:
Example3 (Both bounding box and thickness = ON)
Thin bodies that lie within the given range:
Note: Scripting support is available only for Delete option.
