TRAPEZPER function
Interest
The TRAPEZPER function allows creating periodic trapezoidal signals.
Definition
The TRAPEZPER (X,X1,X2,X3,X4,X5,X6,X7) function is a periodic trapezoidal function whose arguments X, X1, X2 , X3, X4 , X5, X6 and X7 are explained in the block below.
Note: The arguments X, X1, X2 , X3, X4 , X5, X6 and X7 can be formulas.
Operation mode
In case of transient application, it is possible to define the periodic trapezoidal pulse function shown in the figure below.
Create an I/O parameter: PE = TRAPEZPER (TIME, A, B, Tp, T1, T2, T3, Td)
where:
  • TIME is the time parameter
  • A is the minimal value
  • B is the maximal value
  • Tp is the period
  • T1 is the time interval of linear increase of the function
  • T2 is the time interval of constant value of the function
  • T3 is the time interval of linear decrease of the function
  • Td is the value of initial time delay
An example of the TRAPEZPER function is presented below.
Periodic trapezoidal pulse function: PA(t) = TRAPEZPER (t,0,10,10,2,3,2,1)
