MODULO function
Interest
The MODULO function allows to create periodic signals.
Definition
The MODULO (X,X1 ) function returns:
  • the remainder of the division of X by X1
Note: The arguments X and X1 can be formulas.
Operation mode
In case of transient application, it is possible to define the triangular pulse function described in the figure below.
Create an I/O parameter: PE = MODULO (TIME, Tp ),
where:
  • TIME is the time parameter
  • Tp is the period value
