Python Strings
Strings
Strings can be enclosed using single or double quotes. Strings are immutable.
Group = 'cad_faces'
Group = "cad_faces"
\ can be used to escape the quotes.
status = "doesn\'t match"
print(status)
Output
doesn't match
Strings can be Multiline
Use three double quotes or three single quotes.
str_multiline = """This is an example
for multiline strings."""
print(str_multiline)
Output
This is an example
Strings are Indexed
Strings are array of characters with the first character indexed with 0.
s = "SimLab"
print(s[0])
print(s[5])
Output
S
b
To count from the right, use negative indices
s = "SimLab"
print(s[-1])
print(s[-6])
Output
b
S
To get the sub string
s = "SimLab"
print(s[0:3])
Position 0 included to Position 3 excluded.
Output
Sim
String Methods
len()Returns the length of the string.
s = "SimLab"
len(s) Output
6strip()Removes the white spaces in the beginning and the end of the string.
s = " SimLab "
s.strip()Output
'SimLab'lower()
and upper()Returns the string in lower and upper case.
s = "SimLab"
print(s.lower())
print(s.upper())Output
simlab
SIMLABreplace()Replaces a string with another string.
scriptdir = "d:\projects\scripts"
scriptdir_r = scriptdir.replace("\\","/")
print(scriptdir)
print(scriptdir_r)Output
d:\projects\scripts
d:/projects/scriptssplit()Splits the strings into substrings using the given separator.
xyz = "0,10,15"
xyz_split = xyz.split(",")
print(xyz_split)
print(xyz_split[0])
print(xyz_split[1])
print(xyz_split[2])Output
['0', '10', '15']
0
10
15
