Python Dictionary
Dictionary
Dictionary is a collection of unordered items separated by comma and enclosed within curly brackets.
Items in dictionary have Key and value separated by a colon and they are mutable.
Dictionaries are indexed and do not allow duplicate items.
bodyPropdict = {"Bname" : "head", "Faces" : 10, "Edges" : 25 }
print(bodyPropdict)
Output
{'Faces': 10, 'Edges': 25, 'Bname': 'head'}
Use len() method to find the number of items in the dictionary.
Add items
bodyPropdict["Vertex"] = 8
print(bodyPropdict)
Output
{'Vertex': 8, 'Faces': 10, 'Edges': 25, 'Bname': 'head'}
Remove Items
pop()removes the item with the specified key.
bodyPropdict.pop("Faces")
print(bodyPropdict)
Output
{'Edges': 25, 'Bname': 'head'}Delete Dictionary or Items
del bodyPropdict["Faces"]
print(bodyPropdict)
del bodyPropdict
Output
Clear Dictionary
empties the dictionary.
bodyPropdict.clear()
print(bodyPropdict)
Output
Copy Dictionary
Copies the items in the dictionary to another dictionary.
copy()
blockDict = bodyPropdict.copy()
print(blockDict)
Output
dict()
blockDict = dict(bodyPropdict)
print(blockDict)
Output
Dictionary Trasversal
Access Keys
bodyPropdict = {"Bname" : "head","Faces" : 10,"Edges" : 25}
for e in bodyPropdict:
print(e)
Output
Faces
Edges
Bname
Access Values
print(bodyPropdict[e])
Output
10
25
head
Using values() method
for e in bodyPropdict.values():
print(e)
Output
10
25
head
Access Keys and Values
Using items() method
for k,v in bodyPropdict.items():
print(k,v)
Output
Faces 10
Edges 25
Bname head
Check Dictionary for a Key
if "Faces" in bodyPropdict:
print("Key Found")
Output
Key Found
