Python File Handling
File open
open()opens the specified file.
open(filename, mode)
r read (default)
w write
a append
x creates a file, returns error if exists
Additional attributest text (default)
b binary
f = open("samplefile.txt", "wt") File write
write()writes the content to the file.
f.write("Sample File created successfully.\n")
f.write("Format - Text.")
f.close()
File read
read()reads the entire content from the file.
f = open("samplefile.txt", "rt")print(f.read())
f.close()
Output
Format - Text.
reads a single line from the file.
print(f.readline())
f.close()Output
