getActiveSolutionName
Overview
This utility is used to display the name of the active solution.
simlab. getActiveSolutionName()
Use Case
This utility can be helps us in defining or modifying the solution parameters in scripts where the name of the active solution is required.
Utility Input
Sample
Note: sample script
