*DEFINE_COORDINATE_SYSTEM
LS-DYNA Input Interface KeywordThis keyword defines a fixed coordinate system.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_COORDINATE_SYSTEM | |||||||
| CID | X0 | Y0 | Z0 | X1 | Y1 | Z1 | |
| XP | YP | ZP | |||||
Definition
| CID | Coordinate system identifier. (Integer) |
| X0, Y0, Z0 | Coordinates of system origin. (Real) |
| X1, X2, X3 | Coordinates of the point determining the X
axis. (Real) |
| XP, YP, ZP | Coordinates of the point determining the XY
plane. (Real) |
- This keyword maps to /SKEW/FIX.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
