*DEFINE_TRANSFORMATION
LS-DYNA Input Interface KeywordDefines a node and entities transformation(s) used in *INCLUDE_TRANSFORM.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_TRANSFORMATION | |||||||
| TRA_ID | |||||||
| Option | Param_1 | Param_2 | Param_3 | Param_4 | Param_5 | Param_6 | Param_7 |
Definition
| TRA_ID | Transformation
ID. (Integer) |
| Option |
| Param_1 | If Option
| Param_2 | If Option
for MIRROR, SCALE, ROTATE |
| Param_3 | If Option
For Format if all Param are use:
For Alternate Format if values of Param_4 to Param_7 are 0: |
| Param_4 | If Option
| Param_5 | If Option
| Param_6 | If Option
| Param_7 |
- This keyword maps to /TRANSFORM.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
- There are 2 alternate input format options for the option ROTATE, where all parameter fields are entered, they define the vector (Param_1-Param_3), coordinates (Param_4-Param_6) and angle (Param_7) of rotation, where only Param_1-Param_3 are entered, they describe 2 node IDs defining vector (Param_1-Param_2) and angle of rotation (Param_3).
